Need to add you have to have the tools and know how to correctly use them to check everything. Trust not one thing.We have on average around 120hrs in each race engine and we have been doing it for a very long time.Shop door is locked,no radio,total concentration on what is in front of you.Your eyes is the final decision.No do overs!!.
well heres is the whole deal im looking to put together
as i said 434 ci and its been suggested i go with the afr 235 or 245 cc heads instead of the 227's solid roller cam single plane efi intake twin 66 to 70 mm turbos ideally i need to make around 1,200 hp to be competive really not a hard feat with the layout of the combo i know i want the big thing is it must remain streetable and i dont mean the once a month 30 mile trip. this thing has to live on 400 mile round trips to and from the racetrack so my main concern is really going to be in the roller lifters and valve train, i dont need a lifter leaving me on the side of the highway on the way to or from the track and i know on a bunch of forums there alot of discusiion about some of the solid roller lifters failing from different companys im also not dead set on the 434ci as if this class comes to the local track there maybe a displacement restrictions so im keeping an eye on what happens before i order any rotating assembly |
I dont see why you cannot make 1500 hp with a twin turbo 434 with 245 heads. injestion and computer controlled ignition and race gas. streetable? lower the boost to 7 pounds while on the street.
we have a fellow board member thats making close to or just over 1000hp with a 406,afr heads,single plane and twin 66's with relativley low boost on pump gas. his is pretty much just a street car though he didnt build it to race in a class. so i have no doubts a 434 with the same heads will get me were i need to be |
If your going to build a 434 use a tall deck Iron Eagle block. Using a 9.000 deck block you have to much pisotn hanging out of the bore at BDC which will be a problem down the road. A std. deck block to small of base circle cam rod ratio is not good, stroker pan which skips every other bolt hole which = leaks. Now using a 3.875 X 4.185 which is a 427 is pretty common in our shops, Just saying. Here is a quote from another shop on 4.0 strokes in 9.000 block. Quote:
Here is a link to verify what I am talking about. Roller lifter roundness - Yellow Bullet Forums The best lifter on the market by far is the Jesels, There sizing is very good and there lifters are DLC coated as well I have seen about every lifter made and second best would be the Morels. |
thanks that seems to go with everything ive been reading latley on lifters. any chance u know the cost on a set off hand? |
Those liftres are around 1350 a set. If your worried about cost over quality you can probably find a cheap set on EBAY. |
We went through lifter bore issues with the 565 and had two trusted machine shops that failed to get it right.It was after that we fixed the problem ourselfs.Then knowing that,in building the 632 the Jesel's where the lifter of choice.
Northeast huh.Want to tell us what city??. Maybe change your signature.
| Olds Rocket block info needed | MightyMouse4466 | Engine | 4 | 01-27-2008 08:40 PM |
| 350 Rocket Block Number | jpd37 | Engine | 4 | 01-19-2008 01:01 PM |
| p-17 Rocket says Hi Ya All | p-17Rocket | Introduce Yourself | 1 | 10-30-2007 03:05 PM |
| new retro-rocket on the block | hotdogracer | Introduce Yourself | 1 | 10-23-2007 02:11 PM |
| 350 Rocket Block | CLJeepster | Engine | 1 | 05-03-2004 07:44 AM |
