gm rocket block - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 10-31-2012, 11:28 AM
CNC Blocks Northeast
Originally Posted by 1Gary View Post
Northeast huh.Want to tell us what city??. Maybe change your signature.
Gorham, Maine
  #47 (permalink)
Old 11-01-2012, 12:13 AM
been talking to a fellow board member with a twin turbo 406 and i think im going to go with a hyd roller instead of a solid as he is running .640 lift on his morel lifters with no issues, and i dont plan on going any higher then that
  #48 (permalink)
Old 11-01-2012, 08:24 AM
Morel has a .904 hyd lifter they just came out with that being said the Dart SHP PRO block would be a good choice with the BBC cam tunnel, 4 bolt billet caps from front to rear and its about 330.00 more then the std. SHP block.
  #49 (permalink)
Old 11-01-2012, 04:52 PM
thats the combo he is running in his car
  #50 (permalink)
Old 01-04-2013, 01:37 AM
i figured i would update this i ended up buying a tall deck iron eagle block , with the bbc cam tunnel,
i did purchase 4 inch stroke crank but was able to sent it back in for the 3.875 stroke crank.im going with the 427ci build instead 3.875 x 4.185 with a 6 inch rod
i havent decided on a piston yet as i can get the afr 245s with a 70 or 80cc chamber and im waiting to hear back from some ppl running the 245 heads with the different chambers to see if i should get the 70 or 80's
other then that i need to come up with a cam and then ill be able to start assembling it
im going to run a pair of 70 or 76mm turbos on this engine should be able to make 1400/1,500 hp pretty damn easily
  #51 (permalink)
Old 01-04-2013, 08:13 AM
Where do you want to be for compression.
On your build I would go to a .904 lifter to reduce the pressure angle of the lifter.
With the tall deck I would have gone with the DRCE-3 oiling at no charge and gone to a 55MM cam which makes for a much better profile, You can't get a big enough base circle cam LOL.
  #52 (permalink)
Old 01-04-2013, 08:43 AM
vinniekq2's Avatar
I dont understand why you didnt use an LS-X combo. 245 cc heads are available.NRE builds street versions that make that much power.and the alien FI is supposed to work well
  #53 (permalink)
Old 01-04-2013, 05:06 PM
had to save a lil money were i could, am going with the larger lifters still trying to decide between hyd roller or solid roller, my friend is running the hyd roller and i think i may go that way to make it a lil more street friendly
as much as i hate to im going to go low on the compression at around 8.2-8.5-1 since this engine will see alot more boost then i would normally run i.e around 30 psi . if e85 was more redilly available in my area i would deff go for 9.5-1 cr
typically on my street strip suff i built before i set up the engines with a min of 9.0-1 cr and a max of around 9.7-1
the ls stuff is still pretty expsensive more so then the gen 1 stuff when u start getting into hardcore racing parts , im going to make my venture into the lsx series of engines soon though im thinkng about buying a 4.8 or 5.3 and slapping a 76 or 88 mm turbo on it in an s10 pickup
  #54 (permalink)
Old 03-30-2013, 11:21 PM
is this a no brainer on a complet carb to pan deal on a GM rocket motor?
today I was picking up some camaro parts from an old racer that had retired and is down to his last few pieces and on his engine stand he had a built 415ci rocket block motor with the dyno sheet showing over 440hp and 500ft pounds of torque, he had all the receipts ,dyno sheet, carb to pan, etc, he said all I had to do was drop it in and set the timing, it was built as a cheater motor with a custom cast iron intake made, chevy bowtie heads, and he claimed that if I changed intake and used headers instead of manifolds like he did it would be a 40 to 60 hp gain, he also said it had 9.5 compression so it ran on pump gas , he had $13k into it and it said he had it in a street legal car and it hardly had 1k miles on it, he told me $4000 takes it, my question is installed on a dyno or running, what kind of value is it worth? I am kinda new to all this top notch race stuff, is it a good deal, decent deal? any help is greatly appreciated
Olds Rocket block info needed MightyMouse4466 Engine 4 01-27-2008 08:40 PM
350 Rocket Block Number jpd37 Engine 4 01-19-2008 01:01 PM
p-17 Rocket says Hi Ya All p-17Rocket Introduce Yourself 1 10-30-2007 03:05 PM
new retro-rocket on the block hotdogracer Introduce Yourself 1 10-23-2007 02:11 PM
350 Rocket Block CLJeepster Engine 1 05-03-2004 07:44 AM
