gm rocket block - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2012, 01:48 AM
gm rocket block
my friend had picked up an gm rocket block a few years ago
unfinshed bores and lifter bores
bbc cam bearings
400 mains
wet sump
tall deck block
max displacement is 455ci
i can purchase this block for 2,200 bucks , how stong are these gm blocks
reason im asking is i am building a 434ci twin turbo small block to run in x275
it will be 434ci 9.5-1 cr, with cnc afr 227 heads, solid roller cam , single plane efi intake with twin 66mm turbos
this combo is capable of 1000hp plus easy
with this block handle it or should i just buy a little m
Old 10-27-2012, 07:27 AM
If a true GM Performance "Rocket", it will be fine. That was Oldsmobile's "version" (thus the name "Rocket") of the 400SB, raising the cam and using the BBC timing set. The tall deck allows for longer connecting rods, a "must" for high RPM durability. Several years ago, we built an 1,800HP blown/alcohol 434 using the Rocket block and "splay valve" heads. 9,500 RPM, lived fine, went 6.60s in a LWD.
Jim
Old 10-27-2012, 07:48 AM
Last journal entry: was hoping for better than this
if it's a true rocket.. it's what the prostockers used..
Old 10-27-2012, 08:02 AM
Prostockers used the DRCE I and II(Big Blocks)
The Rocket Block is a small block
Old 10-27-2012, 08:35 AM
vinniekq2's Avatar
there used to be a pro stock truck series that raced small blocks.I dont know what blocks they used though.
Old 10-27-2012, 09:35 AM
it might have been the trucks..
could've sworn jeff smith showed a warren johnson bullet rocket block based mill in the early 90's
Old 10-27-2012, 09:59 AM
68NovaSS's Avatar
Wiki Edits: 9
There were pro stock small blocks back in the day, around '72 - '81, then again in '98 for the trucks, mostly 358 c.i....how far back was the Rocket block produced?
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 10-27-2012, 02:24 PM
this one was iirc late 90's
Old 10-27-2012, 03:03 PM
thanks guys i am not familiar with the rocket blocks at all
i know it needs a special oil pan since the oil pan rails are spread, now i just need to figure out the cost of assembling it versus getting a little m block and see how much cost difference there is
Old 10-27-2012, 06:56 PM
vinniekq2's Avatar
I paid 2300 for my little "M" in Canada
Old 10-28-2012, 01:58 AM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
Chevy Small Blocks - Engine Blocks
Old 10-28-2012, 07:06 AM
1Gary's Avatar
I already did something similar with a bare casting Bowtie 4.3 block.I can tell you unless you have a machine shop your never going to get a bare casting completed as cheaply as one that is already done. And my point of the link is those do come in various models and costs accordingly.
Old 10-28-2012, 09:43 AM
For those who don't remember, Oldsmobile heavily sponsored drag racers in the late 1980s. There were MANY Olds-bodied Super Stocker Cutlass Calais and Ciera cars with F.J. Smith RWD conversions using "corporate" motors. Olds designed the Rocket Block to fix many stock SBC shortcomings (as they did with the BBC in the DRCE motors). The "rocket block" nomenclature comes from the fact that there was an Olds rocket logo cast into the side of the block. It was never used for Pro Stock because the Pro Stock engines were 500 cu in by then, thus the use of the DRCE in that class.
Old 10-28-2012, 09:49 AM
There is no comparison between Rocket and Little M. Little M is a very good block, made as a "replacement" block for the 400, only "tough". Rocket is a RACE block. Yes, ProStock Truck is where it was most widely used, IIRC. Virtually everything for Rocket is either custom made or hard to find. That's the "price" of a true race engine. Even a Chevy. Many big block components "fit", as I recall. A custom crank is needed to use the BBC timing set. There's probably some sort of sleeve assembly to make it work if not a "blown" application.
So, if you're looking for the least expensive way to make "big" power and "live", Rocket is probably not for you. If you want the ULTIMATE in SBC technology and the most "bang", regardless of "buck", Rocket is the way to go.
Jim
Old 10-28-2012, 10:20 AM
1Gary's Avatar
Yeah-the biggest bang for your buck is related to how much he wants to spend. So getting right to the core of the topic,how much go you want to spend??. Trying to keep up with corporate sponsorship money is tough on your own dime.
Olds Rocket block info needed MightyMouse4466 Engine 4 01-27-2008 08:40 PM
350 Rocket Block Number jpd37 Engine 4 01-19-2008 01:01 PM
p-17 Rocket says Hi Ya All p-17Rocket Introduce Yourself 1 10-30-2007 03:05 PM
new retro-rocket on the block hotdogracer Introduce Yourself 1 10-23-2007 02:11 PM
350 Rocket Block CLJeepster Engine 1 05-03-2004 07:44 AM
