Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM saginaw pump to Ford Ranger R&P
Old 09-26-2012, 04:32 PM
coryhussey coryhussey is offline
well i figured out my problem last night. I ended up getting another relief valve assembly from a different pump. When i went to install the assembly it wouldnt fit, pulled it out and to my surprise there was a relief valve assembly stuck in the pump, like mentioned beforehand. So i cleaned everything, put it back together, bled the air out that I could, and started the truck. Now for some reason I believe there is too much pressure, as the wheel jerks back and forth overwhelmingly, and you cannot even muscle it to keep it straight. Tried a few things, but nothing seemed to work. I think it is time for a pressure reducer. I hope it works enough and fixes my problem. Now i have the opposite effect where my steering is too touchy now, and scares the hell out of me.
