Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM saginaw pump to Ford Ranger R&P
  #17 (permalink)
Old 10-12-2012, 04:10 AM
coryhussey coryhussey is offline
well i still havent solved my issue yet. I put a adjustable pressure regulator on the pump from heidts, and i still have the jerky back and forth movement as mentioned before. Now it just does it alot less. I am thinking there is an air lock between the pressure relief valve in the pump, and the check valve in the steering rack. I am running out of ideas very quickly
