GM saginaw pump to Ford Ranger R&P - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-28-2012, 06:25 PM
The lines are reversed AT THE RACK. The most forward fitting is pressure, the back fitting is return.
  #17 (permalink)
Old 10-12-2012, 04:10 AM
well i still havent solved my issue yet. I put a adjustable pressure regulator on the pump from heidts, and i still have the jerky back and forth movement as mentioned before. Now it just does it alot less. I am thinking there is an air lock between the pressure relief valve in the pump, and the check valve in the steering rack. I am running out of ideas very quickly
  #18 (permalink)
Old 10-21-2012, 04:03 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
I've said it previously, but I believe your "jerking back and forth" is caused by trapped air in the system, not line reversal.
Read this thread on the FordRangerForum.
  #19 (permalink)
Old 10-21-2012, 05:32 PM
yea i thought that was the case too, but i have properly bled the rack for over 30 min. back and forth to get all the air out. Still nothing has worked, im almost thinking that this ford ranger rack will not work for me. May have to get a custom one made from unisteer
  #20 (permalink)
Old 12-13-2012, 04:50 PM
hey guys here is a pic of the rack. Im assuming the open side is for the return port, and the check valve is for the pressure port?? correct?
  #21 (permalink)
Old 12-13-2012, 05:00 PM
sorry it wouldnt post
Cavalier R&P with Ford pump? ddarnell Suspension - Brakes - Steering 5 05-31-2010 05:27 PM
92 ford ranger motor,tranny & rear end swap 92fordrangerguy Hotrodding Basics 3 07-25-2009 07:20 PM
S-10 & Ranger frame Swaps (Pics & Tech) Abomination Hotrodding Basics 3 11-23-2008 08:26 AM
Is a Saginaw pump compatible with... RookieRodder Suspension - Brakes - Steering 2 02-16-2008 08:33 AM
Ford/Thompson Pump & Buick R&P JAY221 Suspension - Brakes - Steering 1 10-22-2003 03:53 PM
