Is this GM SBC 350 piston a std seize? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2010, 03:51 AM
Hi cleaning up my engine to identfy parts for rebuild.
My cylinder 1 pistons shows 10046106 in the casting.
A.1 4 is stamped on top and a J on the bottom.
What do I have here?
See pictures.
Thanks
ID:	48770   Click image for larger version
ID:	48771   Click image for larger version
Old 10-10-2010, 05:24 AM
BOBCRMAN@aol.com's Avatar
Blocks are measured for bore (+ or - ) size after leaving the final hone. A number/letter is stamped on the oil pan rail for the size of each cyl. bore.
As the engine block moves down the assembly line. The production sees a number/letter stamped on the oil pan rail. A "J" hole gets a "J" piston ring and rod assembly. An "H" gets an "H" etc.
An "A" piston being smaller than a "J" piston. "H" is the most common. All are considered "standard size"
Old 10-10-2010, 11:44 AM
Thanks
Bobcrman
it seems like GM Manufacture Engineering has using a wide band tolerances.
Very unusual that they could not control the bore dimensions.
BR
Bob
Old 10-10-2010, 01:20 PM
DoubleVision's Avatar
Thanks for the cool info Bob. I always was curious on why they stamped letters on the oil pan rail.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
90 sbc 350 bad knock now seize usa3990 Engine 14 06-30-2010 03:07 PM
350 olds into 350 sbc rustynail Engine 1 06-24-2010 04:09 PM
Need Help FAST!!!!!!!!!! millertime85 Engine 14 06-25-2008 07:01 PM
Raw Data: Piston kinematics of four sportsman SBC short block setups Tea Two Engine 0 12-06-2007 08:58 PM
