GM stamp number on Vacuum advance 319 18 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2009, 07:08 AM
Hello everyone
I have an old GM vacuum can and no vacuum gauge to check its specs. Does anyone know what the 319 breaks out to? I know it will pull 18 degrees but dont know when the unit will start pulling in inches of vacuum.
Thanks in advance
Eddy
Old 07-28-2009, 01:18 PM
Hey Eddie. Are you sure that number isn't B19 (vs. 319)?
Checkout http://www.corvette-restoration.com/...c_Adv_Spec.pdf
Pat
Old 07-28-2009, 03:22 PM
Pat
It is an HEI advance, sorry for not stating that. I had a second person believe that it was 319 18 also. I was led to believe that the older GM HEI units had a three digit number and then the total number of degrees the can offered. I will check again tonight to see if it is a B..Just checked and it is 319 18. I am going to find a friend that has a vacuum pump that I can check the specs again. I guess initial oull and then how much vacuum to pull all the timing in.
Thanks again
Eddy
Old 08-03-2009, 12:09 AM
The 319 is the last 3 digits of the GM part number.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Need some clarification on Timing. Any volunteers? Midwest kid Engine 15 07-22-2009 08:45 AM
Thoughts on vacuum advance SBC...confused y2k600f4 Engine 11 05-30-2009 07:01 PM
Ignition timing advance question. Terje Engine 14 07-31-2004 04:03 PM
