GM Starter Solenoid Amp Draw - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2003, 10:08 AM
jamnut's Avatar
Rebuilding AGAIN!!!!
Does anyone know about how many amps a GM Starter Solenoid draws? It's actually the Noid on a hy-torque mini starter, but an average # will help. Or if you can just tell me if it's less than 12 amps?
Old 07-21-2003, 10:23 AM
rnpit's Avatar
Normal starter draw is 60-150 amps depending on the size of the starter. The solenoid should draw between 8-10 amps
Old 07-21-2003, 12:45 PM
jamnut's Avatar
Thanks, that's about what I was thinking. I was going to put a relay into my system, but the starter switch I'm using is good for 30 amps. I'm at the point right now that I have to save money at every corner.
