GM Starters: Repair / Rebuild Information - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2011, 08:51 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
I found this page on repairing GM marine starters. Although it is a marine application (it has the flame shield, which automotive starters do not), I would think that the overall process of taking apart and rebuilding the marine starter should be similar to the automotive version.
"How To Repair The Marine GM Starter"
Old 06-22-2011, 01:07 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
It is, I've done both applications myself, and as you pointed out the only difference is the extra shielding. I'm surprised they don't go into re-building the solenoid!??
Old 06-27-2011, 09:40 AM
Wiki Edits: 132
I'll see if I can dig up some info on the solenoid and post it. Or you can add some info if you like.
Old 06-27-2011, 11:13 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
that's how i used to rebuild them right down to holding it on the ground with my foot and using the jumper cables to test it the only thing it doesn't talk about is the armature itself. if you do all this and it doesn't work then you probably have a bad winding in the armature when you sand down the collar check for cracks or melted insulators there is a process for ohming it out but i'm not sure on the details any more its been a while since i rebuilt one.
Old 06-27-2011, 04:17 PM
Wiki Edits: 132
Hardcore! Ahem I mean kids, don't ever do this.
Glad you brought it up. Hopefully another member can shed light on this. I'll look for info on this as well.
eletrical, general motors, starter, starter repair
Rebuild/repair GM PS pump 75gmck25 Body - Exterior 2 11-19-2010 07:52 AM
for starters nobody1031 General Rodding Tech 3 06-23-2008 08:33 PM
%&@#ING!!! SBC STARTERS!!!! hollywood2k Engine 1 05-27-2007 01:25 PM
Starters Vs Racing Starters Andrew7dg Engine 2 08-26-2004 06:01 AM
information on rebuild of 471/671 blower for 350 chevy 37 chevy Engine 4 03-20-2003 12:05 PM
