-   -   GM Steering Column (http://www.hotrodders.com/forum/gm-steering-column-94487.html)
buckethead1 07-25-2006 08:38 AM
GM Steering Column
Anyone know where can I find a wiring diagram for a 1971 gm van steering column? It is a non tilt column shift with no ignition switch.
astroracer 07-25-2006 10:10 AM
Pick up a Chilton or Haynes repair manual. You may find one at a library to run copies from.
Mark
docvette 07-25-2006 02:22 PM
Doc here, :pimp:
What is it you need to know?
Doc :pimp:
buckethead1 07-26-2006 05:28 AM
I need the color coding for the wiring harness on the colomn so I can connect the turn signals, horn, flashers and lights for the PRNDL. I'm using the column in a 23 T-Bucket.
docvette 07-26-2006 05:26 PM
Doc here, :pimp:
Go here, :
1971 GM van Column Wiring
Should have all you need..
Doc :pimp:
buckethead1 07-28-2006 06:50 AM
Thanks Doc
