GM Steering Column - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2006, 08:38 AM
buckethead1's Avatar
GM Steering Column
Anyone know where can I find a wiring diagram for a 1971 gm van steering column? It is a non tilt column shift with no ignition switch.
Old 07-25-2006, 10:10 AM
STUPID is as STUPID does...
Pick up a Chilton or Haynes repair manual. You may find one at a library to run copies from.
Mark
Old 07-25-2006, 02:22 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
What is it you need to know?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-26-2006, 05:28 AM
I need the color coding for the wiring harness on the colomn so I can connect the turn signals, horn, flashers and lights for the PRNDL. I'm using the column in a 23 T-Bucket.
Old 07-26-2006, 05:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Go here, :
1971 GM van Column Wiring
Should have all you need..
Doc
Innovations
Old 07-28-2006, 06:50 AM
Thanks Doc
GM steering column repair willys36@aol.com Suspension - Brakes - Steering 11 08-28-2010 07:26 AM
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 12:37 AM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 05:55 AM
mounting a GM steering column in a model a straycat60 Suspension - Brakes - Steering 1 04-07-2003 09:48 AM
GM Van Steering Column BillyBob1950 Suspension - Brakes - Steering 3 04-01-2003 10:54 AM
