Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM steering column won't lock!!
Old 03-04-2010, 05:36 PM
APalusky APalusky is offline
Last journal entry: comming along
There is a lever just up from the bottom. I had to cut that lever off. When I was trying to put the mount on the cut off lever moved. That droped the works just a tad so that the clip would not fit back in the slots. I just moved it back over, and lifted the column tube over the lever. Everything fell back into place. The key turns,locks, and I am able to lock the steering column again..
