Gm Steering Wheel Sticky - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-13-2008, 12:04 PM
Saddle Soap possibly?
Shane
  #17 (permalink)
Old 07-13-2008, 09:08 PM
I use Sprayaway glass cleaner on my 79 K10. Its ammonia free, tried it after nothing else seemed to work. After the truck sits awhile it comes back thou.
  #18 (permalink)
Old 07-28-2009, 07:24 PM
I have a 69 camaro that has been setting in the sun uncovered for ten years. The Steering wheel was so bad it was dripping in the seat. I took it off and placed it in a rubber made for 48 hours with dawn soap. I changed the water once and rubbed the wheel with a cloth. All the bubbles where gone and most of the sticky. After that I used a product called hydrasol made by Polywater. This product is made for removing petroleum_based filling greases from Telecommunications cables equipment and tools. My wife loved the smell of it so much she did most of the rubbing. Took about 10 mins but wife stopped after 20. This is good stuff I have also used it to remove the sticky left from window tint.
  #19 (permalink)
Old 07-28-2009, 07:30 PM
302 Z28's Avatar
It is the plasticizer that is added to whatever the wheel is made of to keep it from drying out. Some plastic wheels also have an additive to simulate a hard rubber.
Vince
  #20 (permalink)
Old 07-28-2009, 08:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
3-M Cleaner No. 08984
Originally Posted by pasadenahotrod
Then I got some 3M Adhesive remover (don't remember the number). Had that honey-coated creepy wheel clean and tack free in just an hour or two. Drove the truck for another 2 years and never had to repeat the application even during the summer heat here in Houston.
Ditto! There are a couple other polar solvents that will remove the goo, but they are much more likely to damage other plastic finishes if accidentally applied to the wrong surface.
The can looks like:
Name:	Adhesive Cleaner Degreaser #08984 001.jpg
  #21 (permalink)
Old 02-29-2012, 12:15 PM
3M works
I just wanted to say thank you for the suggestion of the 3M Adhesive Cleaner, it saved my Z28 "Rope" steering wheel. It took about three hours of cleaning with a brass brush, dishwashing detergent and then the 3M, but it really worked well and saved me $$ over replacing. Bonus - I maintain my original steering wheel
  #22 (permalink)
Old 03-01-2012, 07:40 PM
I had a 74 chevy pu with this problem, when I threatened to buy a new steering wheel my wife cleaned the old one with rubbing alcohol. It worked and the problem never returned.
Gear indicator and steering wheel. kringold General Rodding Tech 5 04-29-2007 05:58 AM
37 Ford Pulling Steering Wheel 37FordCoupe Suspension - Brakes - Steering 12 01-28-2007 04:25 PM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
Replacing steering wheel? hcker2000 Interior 5 02-07-2005 12:40 AM
To build own steering wheel or not neil madsen Interior 16 03-07-2003 01:30 AM
