Gm Steering Wheel Sticky - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2007, 11:37 AM
i have a 79 camaro after sitting periods of time the steering wheel gets very sticky . what is the best way to clean this off i have tried super clean - paint thinner
nothing seems to clean it very well . from what i understand this sticky stuff comes from the inside outer cover.
thanks for any help
steve
Old 01-13-2007, 06:08 PM
i have the same problem on my car...the only thing that works halfway decent is that "goo-gone" stuff and a lot of elbow grease.
Old 01-13-2007, 10:08 PM
Ricky Rocket's Avatar
Drive it like a rental!
steering wheel sticky
I know that if you use heavy duty hand cleaner like go-jo it will clean off the black gunky grease. Maybe it will help with the sticky?
Rick
Old 01-14-2007, 01:07 AM
I was driving a 76 El Camino with the nastiest stickyboo wheel ever! I tried lots of stuff with poor results and much labor.
Then I got some 3M Adhesive remover (don't remember the number). Had that honey-coated creepy wheel clean and tack free in just an hour or two. Drove the truck for another 2 years and never had to repeat the application even during the summer heat here in Houston.
Old 01-20-2007, 11:22 AM
GM steering wheel sticky
I have used acetone to wipe off my 70 442 wheel .
rocwal
Dan B
Old 01-20-2007, 01:43 PM
tab's Avatar
tab tab is offline
This is the only tried and true method to clean a sticky steering wheel.
Old 01-20-2007, 02:09 PM
poncho62's Avatar
Wiki Edits: 5
Isn't that...."Animal Cruelty"?................... .Kidding, Joke, Don't get all Bent.
Old 01-22-2007, 07:11 PM
Bonafide Old Car Nut
I have this same problem on my 78 El Camino and have tried many different types of cleaning chemicals with out much luck. All of these posts so far have been how to clean the sticky. I would like to know what it is that is leaking out of my steering wheel and once I know that then maybe I can come up with something that will clean it permanently.
Old 01-22-2007, 07:39 PM
I've always thought it was oils out of a person's hand that were absorbed over years of use then later got released with some soaking in the sun. Maybe I'm wrong but I haven't seen any other plastics do this-most plastics usually dry up not expell oily gunk like on the steering wheels. Also not all the sport wheels do this-I've seen many that have weathered just fine with no residue. I have two stored in my basement right now- one is fine and the other one has the sticky gunk described. I agree a thorough understanding of what the stuff is would steer us in the right direction for removing it.
Old 07-11-2008, 08:33 PM
Sticky Steering wheel
I have had two vehicles that I bought with the sticky steering wheel. 77olds442 and a 7? Chevy truck. I also have a 20 year old letterman jacket and the sleeves are vinyl and are doing the same thing. I did a search on the net and found that old vinyl dolls have the same problem. The restorers use plastic cleaner. P.K. Plastics Cleaner. I'll let you know how it works.
Old 07-11-2008, 09:02 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Hi all,
Same problem with my 69 Camaro wheel. I have had limited success washing the wheel in dishwasher with dish detergents (Wife not happy). I have also used thinner, and other similar products but I've never been able to keep it from coming back once it gets hot in the sun. I have also had many other GM cars with the same problem. I'm kinding thinking on the same line as badbob about oil and grime from our skin. I would think that any chemical solvent based releases from manufactering would have flashed off years ago.
At any rate this is something I've never been able to figure out.
Do other makes of cars have the same problem?
Old 07-11-2008, 09:32 PM
85 Silverado.....same deal.
Shane
Old 07-12-2008, 05:51 PM
Plastics are petroleum based. Heat and time cause the "oil" to cook out. Some goo, some evaporate and get chalky or dry like a dash pad.
Old 07-13-2008, 08:18 AM
I've had the problem on my '79 Trans Am wheel. I cleaned it the best I could and then stitched a Wheelskin cover on it (real leather). It came out nicely.
Old 07-13-2008, 08:39 AM
DRS50's Avatar
Last journal entry: Epoxy primed the body today
This is what a guy from the gm body shop told me and I read it somewhere in a magazine but cant find the article and dont remember what they used to clean the plastic ones, but i remember that they went to a leather cleaner they got from a leather saddle shop, dont know the name of the product they used just know it was used for cleaning leather horse saddles.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Gear indicator and steering wheel. kringold General Rodding Tech 5 04-29-2007 05:58 AM
37 Ford Pulling Steering Wheel 37FordCoupe Suspension - Brakes - Steering 12 01-28-2007 04:25 PM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
Replacing steering wheel? hcker2000 Interior 5 02-07-2005 12:40 AM
To build own steering wheel or not neil madsen Interior 16 03-07-2003 01:30 AM
