GM sterring column ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2009, 09:37 PM
vanislander's Avatar
I'm working on the steering in my 34 ford and noticed that there was a fair bit of play in the GM steering column shaft at the bottom end, I took off the U joint and took apart the clip,cap and guts of the column and all that was in there was a nylon adapter, no bearing? Does any one have an idea what year this column might be so I can get parts. It has tilt, column shift,and ignition.
Thanks for any help.
GM steering column repair willys36@aol.com Suspension - Brakes - Steering 11 08-28-2010 07:26 AM
"Early GM Van" - Tilt column - any pictures? 66GMC Suspension - Brakes - Steering 11 04-16-2007 11:40 PM
36 Ford Banjo wheel to a late GM column Django Interior 8 01-07-2003 07:52 AM
Early GM column shifter & 700r4 56xpresso Transmission - Rearend 2 07-17-2002 02:56 AM
