GM subframe identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2013, 09:33 AM
Hello fellas!
I need some help identifying this GM subframe.
I was told it was out of a Nova, but he was not sure. I know the wheels mean nothing but the aluminum mag wheels that were mounted had "Camaro" center caps.
Do any of you guys have any thoughts or identifiable indicators?
Thanks!
ID:	83122   Click image for larger version
ID:	83130   Click image for larger version
ID:	83138   Click image for larger version
ID:	83146   Click image for larger version
Old 09-23-2013, 09:46 AM
life is a temporary assignment
Could be a G body front clip.Check the hub to hub to see how wide,,, If it's 61.5'' it's a Camaro,,60'' it's a Nova and 58'' it's a G body... I think I'm close just pulling them #'s out my head this early..
Old 09-23-2013, 10:58 AM
I will measure the hub to hub width and get back to you.
I have been looking online, but I am not seeing any subframes with those flat (4 bolt) flanges on the front.
I did find a picture online indicating Nova that had those flanges, but it never indicated what year.
Old 09-23-2013, 11:01 AM
techinspector1's Avatar
Wiki Edits: 326
Seems like this clip was identified as a '78-'80 Camaro on another thread.
Old 09-23-2013, 12:14 PM
It looks like it is 61" wide. That is measured from the base of the wheel studs with the rotors on. From the flat part where the wheels would touch the rotors.
Old 09-23-2013, 05:16 PM
It also has 11" rotors on it.
It will be going in a 1953 Chevy 1/2 ton truck. I want to find out what it came out of so that I can order an Energy Suspension polyurethane bushing kit for it.
Those darn flanges have me stumped though. I have not seen any Camaro subframes that have them.
Old 09-23-2013, 08:49 PM
OK, so it appears that it would be a 1975-79 Nova, Skylark, Omega or Phoenix subframe.
subframe ? old trucke Suspension - Brakes - Steering 4 06-29-2010 08:00 PM
Subframe identification Popadopalis Suspension - Brakes - Steering 4 03-28-2008 09:34 PM
Subframe??? 46fmaster Hotrodding Basics 12 02-10-2007 01:21 AM
Subframe DIXIEPAUL Suspension - Brakes - Steering 3 01-11-2006 01:25 PM
subframe PaulNJ53Ford Suspension - Brakes - Steering 1 10-07-2004 08:21 AM
