GM switch info(application) - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2006, 01:36 PM
I'm installing a EZ2 wire harness in a Toyota Landcruiser and the harness comes ready to go for a GM ignition switch and headlight switch
What would be a good year/model to get an ingnition switch and headlight switch?
The ignition switch has to be a dash mount switch, i can't put it in the column.
Thanks for the help
Brendan
Old 10-22-2006, 04:37 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Your not going to find a dash ignition switch without going all the way back to the mid ~ 60's...I don't think the plugs are the same..Best shot there is take the plug to a bone yard and try it on a few switches..OR convert the plug wiring over to the Land Cruiser switch..
As far as headlamps..pretty much universal electrically..what fits..fits..I think your going to have an easier time finding this than the Ignition on the dash.
You might Give EZ a call they may carry a solution switch for that harness for dash mount.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-22-2006, 05:03 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I used a 75ish HL switch in the 59-------Park lamps on with headlights
The HL switches from the 60's turn the park lamps off with headlights on
Ignition---I used a 63-64 switch----gave me the acc. position, not available before then. Also looks like a 59 switch---no key is needed if not in LOCK pos.
65-68-ignition--does not have the "knob" to turn switch without key. Key can still be removed with the engine running.
69-went to column lock
The harness connector on the kit I used, looks like it would snap on and lock to a 66-67 Chev switch. Plugged onto the 63-64 switch but cannot lock on.
All of these are available thru NAPA, I think they also come with the lock cyl.
Bryan
Old 10-22-2006, 05:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The Chevy ignition had ACC all the way back to 1956..on standard P~210's at least with heater , radio and the like..
BE sure to check the Socket footprint Vs whatever switches you select..
It's a good thing to have hot park lamps in headlight..now~a~days..so I'd stay above the cutoff year IF it matches your socket..
Doc
Innovations
Old 10-22-2006, 07:06 PM
Bryan59EC's Avatar
Standard P-210's-------what are those????
I just know that 59-60 cars had----Lock-Off-On-Start
Not sure about the 61-62
63-64 was the first switch that I found that I could get the Switch/Cyl/Bezel for, and add the Acc. feature.
Asthestics were kind of important on the 59--had to 'appear' that it belonged there.
Classic Industries (and others) have some bezels
Be a good idea to see which switches and bezels are both available.
The bezel is needed to retain the switch in the dash & the threads on the switches/bezels may change from year to year.
(59-60 are different than 63-64)
Bryan
Old 10-22-2006, 11:01 PM
docvette's Avatar
Wiki Edits: 12
Here is an Old Showroom Add for the 1956 Chevy : The Caption reads : 210-4door sedan..The "P" was designation for Passenger..
This is the wire diagram for a 1957, 150, 210, and Belair, Sorry for the crummy photo they don't copy that well anymore....but on the bottom row of switches , just above the lights there, It shows the ignition switch about 3 inches in from the right..The Terminal at about 1 O'Clock is clearly marked "ACC"
Now If you needed a special combination or Bezel and tumbler to gain use of the ACC position I could not tell you..But Electrically it is shown on the switch as a function. Probably Dependant on options selected..(Spot lights, heater, Radio, record player )
BTW: The switches you are looking for can be found HERE:
Ron Francis Wiring
Shoot them an Email on the cost..
Doc
Innovations
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 12:35 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Keeps Blowing Fuse hotrod48 Electrical 17 09-29-2005 12:20 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
