GM T-5 tranny.....no reverse or fifth gear??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2003, 04:52 PM
chevyelc81's Avatar
Post GM T-5 tranny.....no reverse or fifth gear???
The tranny was working fine but my buddy tried loosening what he thought was the oil filler plug. I don't think it was, because he unbolted it as much as he could until I would not turn anymore. When he tightened it back up, the shifter was stuck. So he loosened it up again and now only 1st, 2nd, 3rd, and 4th work. There is no 5th or reverse. The shifter goes in to the 5th and reverse position but it like being in neutral. What did he do????
Old 01-07-2003, 06:27 PM
Post
It was a torx bolt right? That loosens the shift fork (retainer?). You will most likely have to remove the transmission, rear tail housing and top cover to re-position it.
I only rebuilt one t-5 and I remember this piece. Maybe someone will come along and know and easier way to fix your problem.
Old 01-07-2003, 06:29 PM
banned
Post
Take the tranny out... and hit your friend with it.... THEN make him pay a tanny shop to fix it.
