GM tachometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2010, 10:00 PM
GM tachometer
Anyone have experience making GM Tach work with MSD ignition box? 93 full size chevy truck MSD 6 box
Thanks
Old 05-13-2010, 12:01 PM
Thanks
I installed an MSD 6AL box in my 68 Z28 by following the instructions from the MSD web site and my factory tach works perfectly. There are numerous wiring diagrams published on their web site .... one of which you can likely use.
I have asked the MSD techs questions through their 'Forums' and they are very good providing an answer in a timely manner. You could also pick up the phone, call them and get an immediate answer. Good luck.
ZAPPER
Old 05-13-2010, 01:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
If there's a filter somewhere inline in the wire going to the coil from the tach, disconnect it, and connect the wire that goes back to the coil to the MSD "TACH" terminal.
Old 05-16-2010, 11:05 AM
thanks guys I will track down the filter and bypass it. My guess is the filter is buried behind dash.
"Wiring Harness" docvette Electrical 185 10-30-2011 04:17 PM
Important Gm "factory Freak" Cars D M N General Rodding Tech 20 11-06-2008 07:25 AM
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 07:33 PM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 01:47 AM
GM part numbers MI2600 Hotrodders' Lounge 2 11-30-2002 02:23 AM
