Gm Tbi ?
I have a '90' Chevy 350 TBI engine that is going to full throttle upon engine start up.
I unplugged the tps wiring plug but still the same problem. Any ideas where to start troubleshooting? |
Is the TRS Hooked up?
Throttle Return Spring It was worth a shot. R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Also, if you have manually opened the thottle (twisted the lever by hand), the sleeve that is over the cable end may have dropped down over the cable armour, and is holding the throttle open. The return spring on a TBI is wound around the shaft, in between the TBI and the throttle lever. I have also seen small rocks get stuck between the lever and the throttle stop, holding the throttle open.
| Important Gm "factory Freak" Cars | D M N | General Rodding Tech | 20 | 11-06-2008 07:25 AM |
| GM, Wake up ! | onenew32 | Hotrodders' Lounge | 73 | 09-24-2008 07:33 PM |
| Up grading old motor | chevy4x4man | Engine | 10 | 04-25-2008 12:34 AM |
| GM pressures CorvetteStripes.com over trademark issues | Jon | Hotrodders' Lounge | 11 | 02-29-2008 04:04 AM |
| Back up on the dyno. | MK2TMR2 | Hotrodders' Lounge | 33 | 06-23-2005 01:47 AM |
