gm th400 4 bolt- to- 455 pontiac.... how do i make it fit... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 03:30 PM
71_gto's Avatar
gggggrrrrrrrrrrrrr UGLY GOAT
im trying to fit a tranny off of a 400 chevy small block up to a 2 bolt main pontiac 455... the bell housings are way diffrent is there a product out there that will make them compatible or will it fit and im just being retarded... thanks guys
Old 04-03-2005, 05:01 PM
subman17's Avatar
Summit sells a chevy to BOP adapter, its made by advanced adapters. There is also a turbo 400 with that bellhousing on it.
Subman
Old 04-04-2005, 11:39 AM
71_gto's Avatar
so will i have to drill the block or the bellhousing to get this adapter plate to work.. or do you just wedge it in and start boltin away... the chevy tannies peak up and my tranny has like a v wedge in the to of the bellhousing... thanks
Old 04-04-2005, 09:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the adapter bolts the engine to the tranny. you will need to space the converter from the flywheel.
It all bolts in.
Since GM built a tranny bell housing with the correct pattern for your engine I would use the correct tranny case to avoid any possible troubles.
Old 04-04-2005, 10:41 PM
71_gto's Avatar
when i pulled the motor i left the tranny connected... and needless to say some of my drunk buddies decided to take it off... in the air... dropped it and cracked the bell housing right in half...
Old 04-04-2005, 10:42 PM
71_gto's Avatar
plus this other tranny i got is built like a brick sh** house
Old 04-05-2005, 07:58 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A knowledgable tranny person can swap parts to the correct case for your application.
I do not care for adapters when an OE part is availible.
just my opinion.
gook luck,
Old 04-05-2005, 05:43 PM
71_gto's Avatar
do you think they could weld the other bellhousing that came with the motor... it cracked in half.... well almost theres like 1/4 of an inch on one side that didnt break all the way.... its aluminum
Old 04-05-2005, 09:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
No.
mis-alignment would be a problem between the engine crank shaft and tranny pump / converter
Old 04-03-2008, 10:15 PM
you probably figured out everything by now but if you need the adaptor just write me and let me know good luck
Old 04-03-2008, 11:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
i would hope he did fix it.. the thread is 3 years old and the original poster has not logged in for 2 years....
Old 04-04-2008, 06:18 AM
71_gto's Avatar
sorry havent replyed in so long.. but i got her back together.. still sitting in my garage though... needing body work.. someday it'll be done.. lol..
1967 pontiac 455 overheating brisk Engine 11 04-03-2008 10:17 PM
Pontiac 455 or 400 Which is the better engine? johnvomit Engine 10 01-11-2004 05:56 PM
Olds 455 vs. Pontiac 455? bildo95 Engine 3 06-27-2003 04:53 PM
pontiac 455 manifold interchange EricC Engine 2 05-31-2003 08:37 AM
CAN I MAKE MY GM 12 BOLT STRONG ENOUGH TO HANDLE THOUSAND HORSE CAR????? bigbad66chevelle Transmission - Rearend 5 04-11-2003 07:54 AM
