GM Tilt column rebuild? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2013, 09:03 PM
1great40's Avatar
I have a tilt column from an 89 Astro van in my 40 Ford pickup. Recently, have noticed that if you try to turn the wheel with the steering wheel locked, the whole shift "bowl" will move left to right. This doesn't seem to effect the steering at all when driving but I'm guessing there's stuff in there that needs rebuilding. Has anyone overhauled one of these columns? I'm assuming that parts are not too hard to come by.
Old 07-15-2013, 09:50 PM
ogre's Avatar
the 'Duracell Project'
new parts are impossible to find, your stuck with jy parts.
i have an 86 astro van column in my 58 truck and i've had it apart to fix the column lock and new lock cylinder.
pull the wheel off and start disassembling it, fix what's broken and put it back together.
here is an exploded view diagram, disassembley is pretty basic
The Following User Says Thank You to ogre For This Useful Post:
1Gary (07-15-2013)
Old 07-15-2013, 09:56 PM
ogre's Avatar
to pull the turn switch lever out, push the lever in, turn it to the left and pull the lever out
turning it disengages the catch pawls
Old 07-15-2013, 10:19 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Excellent post on the Astro column.I bought off ebay the electrical and factory service manual,but don't have the means of scan and posts the breakdown.Some of the wiring codes are important for cruise,delay wipers,and ignition.So to have that ref in hand and buy those same manuals might not be a bad idea.It has helped me abunch on my Astro project van.
Old 07-16-2013, 08:28 AM
At the bottom of the tilt bowl there are four 1/4" bolts that secure it to the column. They are loose, and allowing the play. Remove them one at a time, and reinstall with red locktite. Unfortunately most of the column has to come apart to get to them, but it can be done in the car.
Here is a good article on repairing one Illustrated tilt steering column disassembly
You can get any needed parts here
Steering Column Parts, Replacement, & How to Instructions
The Following 2 Users Say Thank You to enjenjo For This Useful Post:
1great40 (07-17-2013), Xephius (07-16-2013)
Old 07-23-2013, 09:11 PM
1great40's Avatar
Thanks for the info! I'm sure the 4 bolts are the issue and I just ordered some loctite and the pin remover tool from Amazon. I have a steering wheel puller already and I'm pretty good at getting the lock plate retainer ring off without one of the plate compressing tools. As soon as the stuff shows up, I will get into the column and fix it
Old 07-23-2013, 11:58 PM
evolvo's Avatar
Heathen
I used this guide on my column:
I got a tool just like this one at my local O'reilly parts store, same price, too!
Performance Tool W80650 GM Lock Plate Tool - Speedway Motors, America's Oldest Speed Shop
67-68 Ford Mustang Tilt Rebuild Kit or Column needed lconnell Suspension - Brakes - Steering 14 02-16-2011 09:33 PM
best tilt column 4b316 General Rodding Tech 5 01-14-2008 04:25 PM
Tilt column rebuild johns37ford Suspension - Brakes - Steering 2 11-26-2006 08:56 AM
looking for a 66 Gm tilt column tomy2tone01 Suspension - Brakes - Steering 0 11-08-2002 07:25 PM
GM tilt column Busted Knuckles Suspension - Brakes - Steering 3 11-07-2002 08:11 PM
