Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM Tilt Telescopic Steering
Old 10-07-2012, 09:15 PM
27Tall T 27Tall T is offline
I have a early '70's Cadillac tilt, telescopic steering where the turn signal does not go into the right signal indent. I push the lever down to get the left signal indent, and it does, but when I push the lever up to go into the right signal indent, the lever runs out of room and hits the column hub before it will go into the indent. I've taken the wheel off and used a screwdriver to place it into the detent, thinking it was a bit of dirt, but when I try to repeat the process I still cannot get it to go into the signal position without using the screwdriver to coax it into position. Is there a quick fix for this or does the signal unit have to be replaced even though it functions as it should except going into the right signal position?
