Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM Tilt Telescopic Steering
Old 10-09-2012, 12:54 AM
enjenjo enjenjo is offline
Look at the turn signal switch on the right side of the column, at the detent. There should be two mousetrap looking springs on the top. If one is missing, it can cause your problem, or if the tab that holds the spring under tension is broken, same thing. You can replace a missing spring with one from a junker, but if the tab on the switch is broken, you will have to replace the switch.
