Thanks for the reply. Took the wheel lock off and got at the switch and saw the two "mousetrap" springs and they are both fine. Cleaned them off, lubricated with a little grease and the switch started to work fine until I put the wheel lock back on and the "C" clip. Then it did the same thing.....wouldn't go into the right signal dedent. Took the lock off and tried the switch.....worked again until the lock was placed back on with the "C" clip. Something has got to be brushing against the switch, don't you think?
