GM transmission whine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2009, 01:51 PM
cletus van damme's Avatar
I have a 86 monte ss with 23k miles on it and the trans also makes a whining sound in 1st gear only. Its a 200r4 and I was thinking it was straight cut gears in teh planetary gears? And if I wanted my th400 in my c10 to whine, will straight cut gears make it do that- and it so where do you buy them?
Old 07-31-2009, 05:27 PM
tnsmith10's Avatar
when will it rain???
turbo 400's did have an option of having straight cut planets, mostly for heavy duty trucks, and motorhomes. as far as the 2004r goes, i have yet to see 1 with straight cut gears.
Old 07-31-2009, 06:03 PM
chlsnk's Avatar
"Love what you do for a living
Gah this is exactly what I am having happen on my C-10.
Old 07-31-2009, 06:50 PM
ill see if i can make a vid tommorw of the monte carlo making the noise. Also it was the th475s that came with the straight cut gears i just read on the net. Only ones i can find are ones from TCI for power glides.
Old 08-01-2009, 06:23 AM
SSedan64's Avatar
Most 2004R's I've seen do whine in 1st gear. Low/Rear planetary.
Old 08-01-2009, 07:52 PM
heres a vid i made real quick
http://www.youtube.com/watch?v=saMXB...e=channel_page
Old 08-02-2009, 04:04 AM
SSedan64's Avatar
Sounds acceptable, as in not going to cause a problem. If you hear or feel grinding or vibration then it's bad. I've heard many that are louder than that and a few quieter.
Pic of part here.>> https://www.wittrans.com/Schematic.a...4R&Schematic=3
Rebuilt units here. >> http://www.ckperformance.com/resourc...hardparts.html
