GM truck charging system ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 01:41 PM
outlaw17's Avatar
Can anyone tell me how the wires for the charging system on a early 90's GM truck run(91 to be exact) ? This engine and all the wiring was installed into a 48 Dodge buisiness mans coupe and the battery must be located in the truck so I would like to know what wires I need to run where ?
The one thing I really want to know is if I have to run a second smaller wire from the battery like the original has ?
***** GO OILERS GO *****
Old 06-03-2005, 03:56 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
alternator wires
There are three wires. One for charging, one for field winding, and one for idiot/voltmeter. The field winding and charging wires feed to the main postive wire on the starter. Both should have fusible links. The charging wire is the largest red wire that connects to the bolt on the alternator. The field wire is the smaller red wire that is connected by the plastic connector. The idiot light wire (usually brown) is the second wire in the plastic connector. It is fed to the idiot light and the light's other wire goes to the fuse box on a switched circuit.
Old 06-03-2005, 04:55 PM
docvette's Avatar
Wiki Edits: 12
one wire or 3 wire?
Doc here,
If it's a 1 wire, The main 10 gauge wire will go to a fuse link on the starter solenoid, Or if equipped, the single lug terminal with the fuse links on it. then run a Black 10 gauge ground wire from the Alternator mount bolt (or Case lug) To The main ground wire by your starter.
If it's a 3 wire, the same as above in addition to: The field wire to be run to the Ignition Buss side of the fuse box, (switched power) and the Indicator wire to the Dash light or Voltmeter, or both Which ever you have.
If you are Carbed, with an Electric Choke, You'll want to parallel that Field wire into a Relay Coil Circuit, and ground, Then on the Contact side of the relay, Run the normally OPEN contact to the Fuse link, and the center wiper to the Electric Choke Coil terminal.
This will give you an Electric Choke that will operate ONLY while the engine is running..so as not to have it open prematurely, should you sit with the ignition "ON" for instance listening to the radio...for 3 minutes or longer, on a dead cold engine, thus defeating the purpose of the Choke, and is factory Stock...
You can ALSO parallel a "Batt" light or LOW Voltage light or CHOKE HTR light from the center wiper...since this relay will Chatter if the diodes ever start to go bad in the altenator...and is a good "first line" troubleshoot device..If the Alternator ever starts to go out.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Battery problem? evltwin Electrical 11 04-10-2005 07:45 PM
Can anyone recommend some mild mods for a 5.7 1993 Z71 Chevy truck Axelrod Hotrodding Basics 8 07-02-2004 09:25 AM
How much should i sell my truck for? onecoomofo Hotrodders' Lounge 15 06-17-2004 11:13 AM
striaght 6 swap into a 55 ford truck brett 6868 General Rodding Tech 1 06-11-2004 11:51 AM
capacitor? no charging? 72Nova Electrical 7 01-07-2003 11:47 AM
