GM truck rear end width - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2010, 09:38 AM
big gear head's Avatar
High Performance Rear Ends
Where can I find information on the width of GM truck rear ends? I need total widths, not that backing plate to backing plate crap. I have an 8.5 that I need to know what it came out of. The total width is 67 1/2 inches and it has 5 lug 28 spline axles. I know it's from '81 to '89, but I need to know if it's 2WD or 4X4 and what it fits. Thanks.
Old 10-15-2010, 10:41 AM
prostreet6t9's Avatar
Differential/Driveline
Being a 5 lug its gonna be a 2WD. I will look thru my lists and see if I find that measurement.
Old 10-15-2010, 12:04 PM
Yea, I was thinking it was 2WD too because of the 5 lug axles, but the width is more like a 4X4.
Old 10-15-2010, 12:30 PM
I dont have any listed at that length either. I'm suspicious that it may be from a van. If you take it apart for some reason measure a axle.
75-88 Chev van 10 ser.
15 ser
75-88 GMC van 1500 ser
2500 ser
28 spline 8.5 with 28 spline axles. 33 5/16 face of flange to the end. But I dont have a measurement for the total width.
Old 10-15-2010, 12:56 PM
I've already rebuilt is and I need to sell it, but I need to know exactly what it fits. I had it listed as a 2WD truck rear end, but I'm not sure that's what it is.
Old 10-22-2010, 03:52 PM
I rebuilt the rear end in a 2WD '85 Chevy truck today and I measured it while I was under the truck. The total width was 63 1/2 inches and the spring perches were 42 1/2 center to center. The rear end that I have is 67 1/2 inches wide and the spring perches are 50 inches center to center. What is this thing out of?
Old 10-23-2010, 12:06 PM
Yes the spring perches are at a different position on 88 and newer than on 87 and older but I dont know exact total widths.
My truck has a problem - rear end bounce Irelands child Hotrodders' Lounge 6 08-31-2010 05:55 PM
GM 12 bolt truck rear axels sbc307 Transmission - Rearend 16 04-23-2010 02:35 PM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Rear End vibration driving me insane 973kgt Transmission - Rearend 41 11-13-2008 11:01 PM
