GM Turbo 400 trans front seal housing question - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 01-13-2005, 02:32 PM
Hi Gary here. I know nothing about transmissions but am replacing the front seal in my turbo 400. When I removed the seal with somewhat difficulty I noticed a small (half moon) shape of a hole towards the bottom (at 5 oclock) in the housing that the seal fits into. Not sure If I put that there trying to remove the seal or is that normal..
Old 01-13-2005, 02:56 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum. This will give you the best chance for a good answer.
