GM Type II P/S Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2006, 06:36 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
GM Type II P/S Pump
I'd like to switch from a Saginaw style PS pump to a newer GM type PS pump. I have the needed brackets and a V-Belt pulley. Are there any other parts needed (other than hoses) to make the newer pump work properly with my PS box (87 Chevy S-10)?
Thanks!
Old 09-28-2006, 08:45 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I am not familiar with the pump you want to use but in my experience, it will work fine. Virtually any pump will work with any gear since all they are is a hydraulic pump and hydraulic cylinder. There are minor considerations occasionally like it is nice to use a pressure regulating valve in a GM pump when used on a Mustang II gear. However since you are going GM to GM I am sure they will trade straight across, no problem.
Old 09-29-2006, 03:12 AM
S10Fan's Avatar
Garage Filler
Thanks Willys36.
The newer pump Im speaking of is the type with a remote reservoir vs the older ones with the reservoir built onto the pump. Most of the newer pumps are used with rack and pinion steering. Im not experienced in the pressure requirements of rack and pinion vs. a steering box.
Old 09-29-2006, 03:36 AM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
power steering pump
Originally Posted by S10Fan
Thanks Willys36.
The �newer� pump I�m speaking of is the type with a remote reservoir vs the older ones with the reservoir built onto the pump. Most of the newer pumps are used with rack and pinion steering. I�m not experienced in the pressure requirements of rack and pinion vs. a steering box.
My 86, S10 has a remote reservoir w/steering box. This is an original GM set-up.
Hope this helps.
Russ
Old 09-30-2006, 12:13 AM
Wiki Edits: 21
Ok, I am familiar with those remote reservoir type. Direct replacement. Will work fine.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
GM distributor/ Oil pump shaft question WBrianS Engine 8 04-15-2004 08:51 AM
type 11 GM power steering pump 37 chevy Suspension - Brakes - Steering 2 07-18-2003 08:59 AM
water pump type markiemyster Engine 5 03-02-2003 05:11 AM
TYPE F FLUID IN A GM TRANS??? ss crazy Transmission - Rearend 10 01-15-2003 07:22 AM
