The 8.5" Pinion Yoke will most likely be a 3R size which is small so you would need to change the Pinion Yoke to use a 1350 U-Joint or use a 3R/1350 Conversion U-Joint & drill the 3R Pinion Yoke for U-Bolts or use Al. Caps.
If you want strength you should change the Pinion Yoke and Slip Yoke to 1350 size to match the DS.
