first off we are talking about 62cc heads right 12370847 This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 234/242; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 539/558. Valve lash is zero/zero and lobe centerline is 112 degrees. 12370846 This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 222/230; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 509/528. Valve lash is zero/zero and lobe centerline is 112 degrees. just so every one knows what we're working with. |
what are you looking for top end bottom end ?
214 intake duration @ .050 for bottom end power 215+ for top end what stall are you running? if stock your best bet would be to start there. |
reason for the 2000 stall was to keep the rpm down on th highway , I just put a built 700r4 this year. (old style tv cable shift with a non lockup converter) (3.08 posi rear) to try and get some low rpm cruising. Why are they listing the 47 cam twice on the cam link ? would it benifit me to just change the rockers from 1.5 to 1.6. these rockers came from a 96 LT4
I predict the truck will be slower with the bigger cam. That cam needs 10.00:1 to 11.50:1 static compression ratio to work correctly and you ain't got it.
The intake valve is gonna close later and not trap enough mixture to increase performance. Just my opinion. Last edited by techinspector1; 09-04-2007 at 04:13 PM. |
If the heads have 62cc chambers, then your 9:1 pistons are definitely dished. You should be able to install the 1.6 ratio rockers and not have to worry about piston to valve clearance.
i agree but at this point all his power now lies in the gearing not in top end.
383 222/230 @ .050 509/528 lift 112 lsa + 3.08 gears = 383 222/230 @ .050 509/528 lift 112 lsa + 3.73 or 4.10= |
My .$.02 Change the gear and run the engine hard with the set up you have !!!
Thanks for all the advice guys. i've thought about it and been told about the gears time after time, i guess it's time to get off my butt and wallet and order a set. It's funny how some of us don't wanna cross that one line, but we'll piss away all kinds of money on alot other BS. 373s here I come.
thanks Rick |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| Cam and rocker ratio change | 70bird | Engine | 0 | 04-03-2007 10:37 PM |
| Chevy l6 cam swap | 74chevyflat | Engine | 1 | 08-09-2006 10:00 AM |
| Rocker or Roller Cam | Fatt Matt05 | General Rodding Tech | 3 | 09-09-2003 09:46 AM |
| Lifter Cam Rocker Arm Question | edog1 | Engine | 11 | 07-30-2003 08:41 AM |
