GM zz4 350 Engine #10243880 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 12:39 AM
Is there a way to get the original specs for this engine?
Old 05-25-2008, 12:49 AM
techinspector1's Avatar
Wiki Edits: 326
10243880, 350CID, 95-00, 4B Main, Gen.I crate motor, roller cam, one piece rear seal, 330HP
I guess it depends on what you mean by original specs. What are you looking for in particular?
Old 05-25-2008, 01:00 AM
Pistons, camshaft type, camshaft lift, camshaft duration cylinder heads, valve size, compression ratio, ignition timing, maximum rpm, thanks......john
Old 05-25-2008, 01:14 AM
Wiki Edits: 326
John, just go to your search engine, type in ZZ4 piston or ZZ4 camshaft or ......whatever..... and you'll find everything you need. Here's just one page on a piston search....
piston #10159436
http://www.gmpartsdirect.com/perform...CATID=856.html
Old 08-15-2009, 04:05 PM
chevyman788
just go to google and type in zz4 350 specs thers plenty of web sites with the specs to that motor.
350 chevy engine surging stanjr41 Engine 1 01-22-2007 01:19 PM
350 engine greg arnswald Engine 1 05-21-2006 03:49 PM
600 cfm Edelbrock jetting for 330hp GM 350 ctw Engine 1 12-15-2005 11:02 PM
350 chev engine numbers forpetesakeorg Transmission - Rearend 2 08-18-2003 08:11 AM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
