gm zz4 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2010, 05:42 PM
gm zz4 engine
I have a zz4 350. the block part #10243880 with edelbrock heads and intake manafold .Engine part #571113(not gm) ser#202896.Can you give any spec.on it.
Old 07-31-2010, 12:15 AM
DoubleVision's Avatar
What specs do you want? Compression ratio? Cam size? Horsepower? Torque? More info please.
Old 07-31-2010, 08:49 AM
a simple google search for ZZ4 turned up MANY hits.
The first is here:
http://www.crateenginedepot.com/ZZ4-...2609-P4C2.aspx
See if this answers your questions...
JA
Old 08-01-2010, 12:43 AM
On my zz4 engine there is a aftermarket tag with the following info part #571113 ser #202896 and NPA1634E1 I would like to know who built the engine.The block is a vortec truck gen1 350 cid 5.7 ltr 4 blt main roller cam and one piece rear seal330 hp casting #10243880.it has edelbrock E=tec170 heads and a performer RPM dual plane intake manifold. any info will be helpful and appreciated.
Old 08-01-2010, 05:25 AM
I'm not sure why you're describing your engine as a ZZ4.
Since it was built by an unknown builder, I don't see how ANYONE can give you any info on it beyond what you already know.
I would suggest that you pose your question to the person/facility from which you aquired the engine.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Need help with GM engine ID Papa Shark Engine 2 04-27-2010 07:19 AM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
piston slap ZZZ GM engine rainer598 Engine 3 08-05-2009 04:14 AM
383 Recipe Sweet Lu Engine 9 10-20-2007 12:01 AM
