We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-23-2008, 12:51 PM
Viet Nam Vette's Avatar
Viet Nam Vette Viet Nam Vette is offline
GM ZZ502 Head Bolt Tightening Pattern & Problem
About 3 weeks ago I changed my 2 year old anti freez in the ZZ 502 which is in my 65 Corvette. I always use the Green Prestone stuff. I ran the motor up and filled the rad to the top. Warmed her up and took her for a cruz. Checked her out and no leakes anywhere.
After I came back and shut her down ...I waited for the motor to do it's normal thing which is to "Puke " out what she don't need. After a few min's she puked about a pt or so and leveled off about 1'' below the rad cap.
All was fine. The Corvette is store outside in a "Cover It" tent inside a "Car Capsaul" wher the air is changed 4 times every hour. Today I took he out for a spin as the temp droped to about 45*. It's been cold up here in the South Jersey area.
After coming back I noticed a drip from under ther vette. I jacked her up and saw the head gasket is wet in one place and dips about once every 10 seconds. After a while it stopped when the pressure and temp dropped off.
Either I need to check my Headbolt torque ..or repace the gasket. Tried to find the Head Bolt torque Pattern on the web but no luck. Anyone have a copy of that. The ZZ 502 uses Aluminum Oval Port Heads on the Gen V BB .
Why would that sucker start leaking....after 2 years?? I kmow it's because I chnged the Antifreez..
Any help would be appreciated. Thanks in Advance.
Old 11-23-2008, 01:49 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
1BAD80's barnstar
Wiki editor
Last wiki edit: How to adjust valves
Wiki Edits: 2
The Knowledge Base on this site has the info,
http://www.hotrodders.com/kb/chevrolet-engine-tech
If it's leaking it was not sealed correctly to began with, I use Permatex #2 with very good retaining of the seal.
Check all the hose's before pulling off the heads, maybe a pressure test on the coolant system.
Luv the smell of NITRO in the morning.
Old 11-23-2008, 02:08 PM
Thanks Bad 80,
I must have missed that. I did check the Knowledge Base before I posted.
This is a GMPP ZZ502 Deluxe factory assembled Crate motor. I don't want to have to pull the head,. I'll have to if the Head bolts are at the Torque spec.
Old 11-23-2008, 02:20 PM
Nothing in there on a GMZZ502. All references are made to a 502 with smaller valves and and rectanular ports. My motor has oval ports. Guess I'll have to contact GM
1BAD80's Avatar
1BAD80's barnstar
Wiki editor
Wiki Edits: 2
It can be 1 or 2 bolts leaking from the threads, the heads do not have to be pulled to fix it, you will have to drain the block and pull the bolt/studs out one at a time and use the Permatex#2 for good sealing & re-torque.
Pull the valve coverts to check if their leaking inside also. LOL
Old 11-23-2008, 02:25 PM
Yeah.. plan on pulling the covers and peeking inside. Also checked the oil...looks good.
I had a simular problem on my early 86 Vette with FI and an Aluminum intake on an Iron head. Had to pull a few intake bolts as the green goo was weeping up the bolt threads and making a nice swiming pool for the bugs in the intake runner valley.
Still need the tightening Pattern.....Rats!!!
Old 11-23-2008, 02:36 PM
1BAD80's Avatar
1BAD80's barnstar
Wiki editor
Wiki Edits: 2
Old 11-23-2008, 03:00 PM
Thanks George...You Da Man.....!!!
I know Edelbrock makes the heads and intake for GM on the 502. I have the torque specs and amount of tightening passes in my manual. The Torque spec on Edelbrock site are different.
The Factory manual I have says Long Bolts Final Pass 75 lbs....Short Bolts..65 lbs final Pass. But the main thing is I have the Pattern Now. Thanks Again for taking the time to search for me.
Also I sent you an email to the address you sent me in the PM.
Thanks Again. Mark
Old 11-23-2008, 04:58 PM
1BAD80's Avatar
1BAD80's barnstar
Wiki editor
Wiki Edits: 2
From the manual Torque in step's,
Step
1 40#
2 60#
3 80#
Note:
ON BIG blocks with aluminum heads, tighten the short bolts to 65# and the long to 75#
Old 11-23-2008, 05:44 PM
1BAD80's Avatar
1BAD80's barnstar
Wiki editor
Wiki Edits: 2
Here is a scan from my manual.
Name:  Head Bolt Pattern 001.jpg
Old 11-23-2008, 05:59 PM
Step
1 40#
2 60#
3 80#
Note:
Yep you got it.....
From the 502/502 Manual....
Long Bolts First Pass 25 lbs
" Second Pass 50 lbs
" Final Pass 75 lbs
Short Bolts First Pass 20 lbs
" Second Pass 40 lbs
" Final Pass 65 lbs
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "GM ZZ502 Head Bolt Tightening Pattern & Problem"
Questions on a GM 14 bolt rear. 1tunda Transmission - Rearend 8 12-26-2008 09:13 PM
chevy 265 head bolt tourqe pattern tomaube Engine 1 10-27-2006 08:21 PM
37-48 Ford Spindle bolt pattern? farna Suspension - Brakes - Steering 1 06-02-2006 11:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 01:02 PM
