GM12 bolt for 58 apache - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 03:04 PM
DOUBLEDICK's Avatar
I have been to the wrecking yard and done the measurements and the rearend out of a late 70's chevy truck has the proper offset to fit under my 58 apache.Does anyone know of a aftermarket kit with weld on leaf pads?If not I will have to cut the pads off mine and weld them to the later model GM 12bolt.
Old 11-20-2005, 03:08 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
Summit has them . I think from morroso.
Good luck with the swap.
Old 11-20-2005, 03:21 PM
DOUBLEDICK's Avatar
Thanks I will go look at summit now
Old 11-20-2005, 03:33 PM
DOUBLEDICK's Avatar
All I could find is 2.50 wide.I need 2.00 wide for these old 2 inch leafs.
Old 11-21-2005, 01:27 AM
Yep , your right.
I made them myself for that reason.
A company that has them for sure is www.nolimit.net
Check out there site , the make cool stuf for the old pickups.
Succes.
Old 11-21-2005, 11:33 AM
DOUBLEDICK's Avatar
Thank you.Those are perfect for this job.I will get them ordered.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Bolt Strength Question jamnut Engine 16 03-30-2005 07:11 AM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
GM12 bolt ID toooofastforu Transmission - Rearend 1 01-23-2004 06:05 PM
