I'm rebuilding a GM125C trans in a'85 cavalier (considering doing my '84
caravan also) but several tools I may need(?) are prohibitively expensive. As a retired machinist I can make what I need, but need the dimensions. If anyone has done one of these, do you really need the special tools? The ones I think I need are the "J" numbers are from my ATSG TECHTRAN Manual and the "T" numbers are I believe ATEC numbers (Fron TRANSTAR catalog)J-29829-1,J-29829-2/T1274-A Turbine Shaft Seal Installer/Resizer Case Side; J-29569-1,J-29569-2/T1274 Turbine Shaft Seal Installer/Resizer cover side; J-28545/T1202-A Clutch Assm & Final Drive Remover & Installer; J-28542/T1059-B Lo-Reverse Clutch Center Support Unit Remover & Installer. Does anyone have or know where I can get the machining dimensions to make something that would do the job. <img src="confused.gif" border="0"> |
You may be buying more trouble than you need. I have rebuilt a '56 Hydramatic (many tinmes!), a Turbo 200, a Turbo 350, a turbo 400, a Turbo 7004R and am now working on a Turbo 200R4 and have never needed a special tool that I couldn't make with a cutting torch, grinder and other hand tools. And precious few of those at that. As far as I can tell, those specialty tools are great if you need to do 6 or 7 trannys in a day because you are being paid by the piece, but if you are doing the job for yourself, they can be worked around. With a good set of internal and external snap ring pliers, seal lip tool (small spatula to ease the lip seals into their bores),sockets, hydraulic press and a few other basic tools you should be able to muddle thru just fine. Just get a good instruction manual.
Thanks Willys36! I kind of figured I'd be able to do it without special tools.
