gmc 292 problem pops out of carb when set at any timing no .power - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 08:56 AM
well they say to set it at 8 BTDC still no power pop real bad out of carb .i can get some power back when timing is way way after BTDC any help
Old 04-07-2013, 09:02 AM
vinniekq2's Avatar
should work ok at 12,check to make sure timing is advancing and all plugs are firing correctly.You can use the timing light if its inductive
The Following User Says Thank You to vinniekq2 For This Useful Post:
fordss (04-07-2013)
Old 04-07-2013, 09:10 AM
where it set now it after top dead not even on the timing tab if i got closer to that tab pops out of carb when driving it
Old 04-07-2013, 11:16 AM
bondo's Avatar
Ayuh, there's always the possibility that the poppin' through the carb is from a Lean condition, not related to the ignition timin',...
Have ya checked, 'n changed the fuel filters,..??
Is the carb gettin' good fuel,..??
Is the carb Clean, internally speakin',..??
It ain't goona have any power, if it's starvin' for fuel,....
The Following User Says Thank You to bondo For This Useful Post:
fordss (04-08-2013)
Old 04-08-2013, 02:58 PM
carb is Clean still the same
Old 04-08-2013, 03:15 PM
techinspector1's Avatar
Wiki Edits: 326
Do some simple diagnostics to help you find the problem.
1. Plug a vacuum gauge into a manifold vacuum source and read the results. See this youtube tutorial....
2. Bring the motor up to operating temp, remove all spark plugs, disable the hot wire from the coil, wire the carburetor butterflies wide open and perform a cranking compression test. See this youtube tutorial....
The Following User Says Thank You to techinspector1 For This Useful Post:
fordss (04-08-2013)
1980 gmc 292 l25 power fordss Hotrodding Basics 12 09-24-2012 05:54 AM
Problem with Summit Racing G6600 Timing Set 75gmck25 Engine 2 05-10-2011 10:24 PM
what RPM to set timing & carb??? yragat Engine 3 08-28-2008 01:34 PM
Timing a Carb Nitrous set up. KeithB123 Engine 9 12-07-2003 05:00 PM
How to ID types of Carb on Tri-Power Set up 66 CT Stang Engine 14 01-29-2003 08:29 PM
