GMC 6 cyl engine interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2013, 06:46 AM
Does anyone know if the Chevy/GMC 6 cyl engines 250 Ci or 302 CI will bolt to the 4 speed transmission of a 1959 GMC 1/2 ton pickup currently with a 235 in it?
Old 03-09-2013, 08:44 AM
RWENUTS's Avatar
No!
You need a different bell housing, flywheel for the 250.
Old 03-09-2013, 09:25 AM
I was afraid of that
I was afraid of that. Do you know if the bell housing from a 3 speed will do the job, or do we need to find a 4 speed one?
Old 03-09-2013, 09:31 AM
RWENUTS's Avatar
Not sure. Search here.
The 1947 - Present Chevrolet & GMC Truck Message Board Network - Powered by 67-72chevytrucks.com
Old 03-09-2013, 10:27 AM
Thanks
Thank you very much.
Old 03-09-2013, 04:36 PM
junior stocker's Avatar
IF you are ONLY talking about the transmission bolting to the bellhousing, then yes it will. UNLESS it's the real early (49'-50' back?), torque tube type transmission, and even then, some of them will bolt on also. The bellhousing to engine is a completely different situation, as the later 194-215-230-250-292 engines had the V-8 pattern we're all used to; the 216-235-261 and 248-270-302 GMC are the same pattern wise, but won't bolt to the V-8 pattern (or late six). I "think" that's correct (?). Butch/junior stocker. What are the years you're dealing with?
The Following User Says Thank You to junior stocker For This Useful Post:
pontiac owner (03-10-2013)
ford engine mount interchange? Onefunponcho Hotrodding Basics 4 11-04-2010 10:32 PM
Carb interchange years ? 67 Mustang 6 cyl F&J General Rodding Tech 5 12-14-2008 07:01 PM
Ford Windstar engine interchange jvanbu5132 Engine 4 10-05-2008 08:16 AM
O/D auto for '91 GMC S15 2.5L 4 cyl? XNTRCI-T Transmission - Rearend 9 04-24-2008 10:50 PM
Headers for a 302 inline 6 cyl GMC engine Ed Farrell Engine 4 09-05-2005 08:54 PM
