GMC 87 crew cab body swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2003, 06:33 PM
Has anyone done a body swap on a 1987 crew cab and how difficult is it ? I have a chance to build one complete truck out of two and wanted some input. Thanks for your time
Old 08-18-2003, 07:10 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Not hard at all, just change them
Old 08-18-2003, 08:02 PM
Do you have any suggestions on how to swap the cab with out
the use of a forklift. I dont know how heavy the crew cab is but im sure it weighs a bunch. How many people does it take to lift the cab off and move. Ive never tried it before
Old 08-18-2003, 09:49 PM
drlindz's Avatar
I would suggest building an A-Frame to support the cab while you roll the truck frame out from under it. The A-Frame wouldn't have to be real high if you remove the bed first. I would suppose it would take alot of friends to lift that cab. It took four big guys to lift and move the cab on my Dad's F-100 standard cab.You never know when a well built A-Frame will come in handy.I use mine all the time.
Good Luck!
Old 08-18-2003, 10:53 PM
troy-curt's Avatar
Put a floor jack under each corner,raise it up, remove rear wheels,let frame down at the rear still on a floor jack.roll out frontwards very careful. U may have to remove the rear end to clear the jacks. You could lift from the top, but i`ve seen things get bent that way. hth. Good Luck.
