gmc air bags - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2011, 02:22 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
gmc air bags
I've got a 2001 gmc 3500. The check engine light has been coming on but doesn't seem to change how the truck runs. Will sometimes go out after a while but come back on a few days later. Now the air bag light stays on. For you gm guys is there a sensor that goes bad on these older gmc's on air bag system?
Old 08-30-2011, 05:54 PM
I've had the same symptoms in a non-GM vehicle, and it turned out to be a slightly flat battery. Apparently the electronics (at least in my car) were so sensitive to minor fluctuations in voltage that a little water added to the battery was all it took to fix the problem.
If that isn't it, then I'm thinking some sort of ground fault. But I'll defer to the GM experts on that one!
Best of luck.
Old 08-30-2011, 06:07 PM
T-bucket23's Avatar
Wiki Edits: 26
Air bag light is most likely the clock spring in the steering wheel or on of the switches in a seat belt. If you can find someone witM factory scanner it will tell you where the issue is.
When the check engine light comes on have it scanned. Comming on and off is usually Evap or catalyst.
Chet
4 Bar and air bags 57halfton Suspension - Brakes - Steering 4 10-08-2007 11:03 PM
Air bags Hou 40 Guy Suspension - Brakes - Steering 3 06-07-2007 08:39 AM
air bags on a 72 sweetnlow72 Suspension - Brakes - Steering 2 05-23-2007 06:20 AM
air bags srs xmodracer2006 Introduce Yourself 2 08-19-2006 07:24 PM
air bags acourtjester Engine 6 01-03-2003 12:07 AM
