GMC diff whines - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2003, 08:44 PM
cindyandsean's Avatar
Question GMC diff whines
I have an '89 gmc van.The rear end whines above 35 m.p.h. then is quiet at highway speed(55 or more)also is quiet accellerating uphill.I suppose it's worn carrier bearings am I correct???
Old 10-24-2003, 08:51 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Check the pinion flange (drive shaft) for slop, it's probably the crush sleeve.
Old 10-24-2003, 09:09 PM
Thanks for the reply,
Just went out and checked,hanger(center)bearing rubber is broken loose of the carrier part,but pinnion flange area seems real tight.Just bought the van,had bad axle seal leak may have run low on fluid before I got to it???
