Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GMC Sonoma tranny problem
Old 07-08-2006, 11:37 PM
smileys35 smileys35 is offline
re tranny problem
Sounds like the pilot bearing might be bad, it will jump around and sound like a bad throw out bearing. I had a similar problem once in a nissan while going in reverse. Also sometimes the internal shifting parts vibrate loose and cause a similar noise. The only way to check is to pull the tranny out and spin the main pilot bearing by hand, if it makes noise, it is changeable through the front of the tranny. Hope this helps.
