GMC Sonoma tranny problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2006, 10:31 PM
Hi everyone, my buddy has a 1996 GMC Sonoma 4 cylinder, with a 5 speed manual transmission, and when you start up the truck and and drive it, the tranny makes a sound like when you shake up a bottle of water half empty. Anybody have a solution to this problem?
thanks
Old 07-08-2006, 11:37 PM
re tranny problem
Sounds like the pilot bearing might be bad, it will jump around and sound like a bad throw out bearing. I had a similar problem once in a nissan while going in reverse. Also sometimes the internal shifting parts vibrate loose and cause a similar noise. The only way to check is to pull the tranny out and spin the main pilot bearing by hand, if it makes noise, it is changeable through the front of the tranny. Hope this helps.
Old 07-10-2006, 12:41 AM
sbchevfreak's Avatar
Licenced Automotive Technician
thanks
Does it make this noise in all gaers, or does it go away in 4th?
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
Problem after tranny swap lt1bbody Transmission - Rearend 0 08-04-2005 05:41 PM
Tranny Problem arch Transmission - Rearend 7 07-27-2004 10:34 PM
400 auto tranny in a 72 GMC sprint. gearheadgirl Transmission - Rearend 1 02-18-2003 11:17 AM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
