GMC stumble/hesitation..please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2006, 07:17 PM
jesse01's Avatar
mini me
ok fellers need help once again...thank goodness for this site
anywho we have a 89 GMC 1500 flatbed at work and we can't get it to stop hesitating during acceleration, sometimes it'll do it just cruisin down the road. but if i hit the gas a couple times and floor it it will eventually let up then take off like a rocket
we thaught maybe the catlytic converver might be going bad so we sent to the shop and had a new exhaust put on from the front of the cat. back and the stuburn thing still did it. so Monday we put a fresh tune up on it {plugs, wires, cap, and rotor button} and we also put a new o2 sensor on it. it did good till tonite (weds.) and it started it's crap again and i'm about out of ideas
think the coil might be on it's way out?? if so why would it run fine for 2 and half days then start it's crap again?
it's an 89 GMC 1500 350 TBI. anybody with some other ideas would help
thanx, J
Old 01-18-2006, 08:13 PM
NorthStar's Avatar
Check the throttle position sensor there may be a bad spot.
This can cause computer to get reading that throttle is at idle position when its really not.
Old 01-18-2006, 08:57 PM
tnsmith10's Avatar
when will it rain???
have u checked fuel pressure or the fuel filter? pretty critical with a fuel injected engine. ur going to be looking for 12-18 lbs of fuel pressure...
if the fuel pressure is ok and the filter is clean, a tps could be a possible cause... a good scan tool from a repair shop can check the data flow from the ecm and can check the tps for fluctuations... does it idle ok? another sign of a possible tps is a fluctuating idle.. gl
Old 01-19-2006, 05:09 PM
jesse01's Avatar
mini me
ya, it idles good and it runs good most of the time. it just acts up every now and then
i'll check them couple things when i get a chance
thanx, J
I Need Help Locating 1955 GMC Restoration Cataloges 88cobra Interior 4 04-02-2005 09:33 PM
Chevy v.s GMC truck A-arm lengths? Gearhead forever Suspension - Brakes - Steering 6 09-10-2004 11:15 AM
383 budget buildup advice for a 92 GMC TBI lowlypawn Engine 4 09-04-2004 05:06 PM
48 GMC and Chevy body parts inter-changability Neophyte Body - Exterior 7 05-25-2004 12:02 PM
GMC 1/2 ton A-Arms v.s. Chevy? Gearhead forever Suspension - Brakes - Steering 1 09-23-2003 08:49 PM
