I believe you have to take the outer casing off the top part of the column, and there is threaded holes in the pivot pins. If I remember correctly, thread a screw into these holes and use a slide hammer to pull them out. Also, take the spring out before you do this...just use a big screwdriver to press and turn the hold down cap thing(real technical, eh?) I did this recently in my 86, but I'll be damned if I can remember how its done.
By the way, I like your username 86GMC |
I'm going to be rebuilding the steering column in my '84 Chevy. I was debating on how to "carry" it into my project journal. You're thread is making me lean towards step by step with pictures every step of the way. Thank you.
In a while, Chet. |
Yeah, I'll be very thorough on the details so any "newbie" should be able to follow along and do the same thing. I have a couple of other GM tilt columns out of other cars too. I think they are all fairly similar.
In a while, Chet. |
Try this
http://www.necoa.org/article95.html |
Triaged, that is exactly what I had in mind....
Thanks for putting that link in, Chet. |
| All Wheel Drive GMC Van | BigDawgsEatFirst | Transmission - Rearend | 6 | 09-28-2005 04:14 PM |
| Can't get my tilt wheel apart... | gator412 | Suspension - Brakes - Steering | 14 | 03-02-2005 03:11 PM |
| Tilt Wheel | Jim Vines | Suspension - Brakes - Steering | 1 | 06-24-2003 10:12 PM |
| Tilt Wheel | Jim Vines | Suspension - Brakes - Steering | 1 | 05-12-2003 09:33 AM |
| 1986 F350 XLT tilt wheel ??? | BeerMan | Suspension - Brakes - Steering | 8 | 03-07-2003 07:28 AM |
