GMC transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2006, 11:01 AM
GMC transmission
I have a 62 GMC panel truck,305 V6 ,3 speed[was]. Lost second/third gear. Don't know if there is a common problem with these. Will start on it tonight.My main concern is replacement parts. Is this trans GMC only,or was it shared with Chevy? Thanks for the help.Found the problem! Shifter fork is dead meat. At least it didn't get wound up in the gears. Fell into the bottom of the case. Need 2nd/3rd shifter fork. Where to find? Thanks again.
Old 10-25-2006, 06:53 PM
gmc transmission
when I get back to the shop tomorrow I'll check,will post info I find,but rockland standard gear,in New York,does come to mind.
Old 10-26-2006, 06:58 AM
gmc transmission
hey jamn50,here's a number for you.1-800-835-1007 the company name is A& Reds trans parts.They have inventory dating back to 1946,found their # in transmission digest.I have not bought from them,but I have called them,they are very helpful,and gracious with their time,hope this helps.
Old 10-26-2006, 07:30 PM
Trans fix
Got this part with all of your help! Back on the road again! Thanks. Cary.
Old 10-26-2006, 09:15 PM
GMC transmission
Glad to help Cary.Briscoe
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Transmission Question(1989 GMC) telephone man Transmission - Rearend 7 01-02-2006 12:23 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
