GMC Transmission Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2008, 02:58 PM
Hello All. New to the site, very good answers I have seen. I have a 700R4 GMC transmission. All I have is Low gear and reverse. I have read it is likely solenoid in transmission. Anyone out there experienced these problems?
Old 01-15-2008, 06:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
year of vehicle / trans? Mileage ?
If you have a TV cable on this trans have you checked that for proper operation & adjustment?
Could be a broken governor gear.
Old 01-15-2008, 06:53 PM
brian0605's Avatar
mostly confused
Last journal entry:
I'd be inclined to go with the governor. You can usually pick one up for around 10$ used at most transmission shops and it is probably the quickest and least invasive thing to check. Brian
Old 01-16-2008, 03:39 PM
Many Thanks
Removed the governor gear and 3 teeth gone and valve was stuck shut. $15 for the entire assembly and shifts fine. Thank you for replying
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
can a leak on the intake manifold cause problem when my transmission shifts dopey Transmission - Rearend 7 08-01-2004 10:43 AM
transmission problem smallz Transmission - Rearend 5 05-31-2003 11:47 AM
problem with ford transmission ,please help mikeweyman Transmission - Rearend 6 05-24-2003 07:02 PM
problem with ford transmission ,please help mikeweyman Transmission - Rearend 2 05-22-2003 11:58 AM
