GM's new engine! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2012, 09:25 AM
bigdog7373's Avatar
Of course it's fast
GM's new engine!
Well here's the replacement for the LS series engines! I'm not sure why they called it the LT series again, but it is what it is.
Read about it here: Breaking News: Chevy Gen V Small-block Reveal - CorvetteOnline
Old 10-26-2012, 04:34 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Any comments ?
Old 10-26-2012, 05:57 PM
Banned User
i was just thinking about this today----that the original small block went 42 years before being "succeeded" by the LS engine. And the Ls engine "only" lasted 15 years before getting replaced. Which indicates that is gen 5 engine must be REALLY GOOD on top of the already phenomenal LS engine?!?
a) Will gm continue to produce the LS engine---as they do the original small block? Will it continue to be installed in production vehicles--namely pickups?
b) It appears they are going back to using a mechanical fuel pump? Interesting.
Old 10-26-2012, 06:17 PM
Last journal entry: was hoping for better than this
I think in that 42 year run. they just didn't change the code everytime they changed one thing..
with todays computer indexing systems it's most likely easier to index parts this way..
Old 10-26-2012, 07:09 PM
the enw engine should be really nice but i see a few problems, it has already been stated by gm engineers that the ecm running these engines will not be able to be cracked or tuned, and any tampering will cause them ecm to shut down and engine will not run.
if this is truley the case i do not seeing this being a popular engine until some companys come out with a standalone system to run the engine
also how much hp can this new cam driven fuel pump supply if it cant supply much more then stock well there goes the ability for engine mods
Old 10-26-2012, 07:22 PM
Banned User
The other question besides how many lbs pressure can the pump provide is why go back to mechanical in the first place?
Old 10-26-2012, 11:47 PM
lets see..
safety.. you don't have a fuel line going the lenth of the car with 60-80psi of fuel..
cheaper..
less of a drain on an already overtaxed 12-14 volt system
less of a delay on fuel pressure changes..
Old 10-26-2012, 11:49 PM
it's not so much that the code will be hard to crack...
it'll be hard to crack and then return to stock tune after you blow it up and bring it back for warranty repairs..
Old 10-26-2012, 11:51 PM
bigdog7373's Avatar
Of course it's fast
Because the direct injection requires very high pressures, which the mechanical pump i guess is better suited to provide. It still needs an electric low pressure pump though.
Just remeber that when the LS first came out everyone said the same thing about not being able to get into the ecm, now look at us.
I just hope they keep producing the LS engines. They are perfect for hotrodding since they are not too complicated. This new motor will make for some pretty interesting swaps though. I just wonder how the direct injection will respond to modifications. Also, I can't be the only one who hates drive-by-wire!
Old 10-27-2012, 02:27 AM
the new ecms are aparently internet enabled and the ecm checks back to a gm database to check out the ecm. ill have to find the article
if this is the case then a complete reflash of the ecm with all new code would be needed to do anything with the ecm
Old 10-27-2012, 02:35 AM
or sign on the dotted line.. of the warranty waiver
Old 10-27-2012, 09:04 PM
bigdog7373's Avatar
Of course it's fast
The name they gave it really bothers me! Now we have the LT-1, the LT1 and the LT1. Yet they are all completely different. Why gm? Whyyy!?
Old 10-27-2012, 09:56 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
They (and other auto mfrs) have been re-using badges, trademarks, and terms over and over again since the 50's at least.
My "conspiracy theory" is that they do these things to drive us parts people crazy!
Old 10-27-2012, 11:53 PM
bigdog7373's Avatar
Of course it's fast
Just with gm off the top of my head:
ZL1
LS6
LT1
442 (changed meanings at least once)
Turbo fire, jet, thrust, glide, hydromatic. Yet none had anything to do with a turbo.
"Vortec" has been used to label a few different engines
Old 10-28-2012, 05:44 PM
ProStreetRob's Avatar
Blown 502
Compression ratio: 11.5:1
WOW, Dont know that I would want to throw a Big Blower on that
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
Ford 302 engine to engine stand bolt size? Lee in Texas Engine 4 03-24-2008 10:30 AM
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 12:11 PM
